Version 2017, Build 1.4 released!
Version 2017, Build 1.4 is ready! To upgrade, go to
www.wxsim.com/wxsimupg.exe
If you don’t already have the program, use the demo installer
www.wxsim.com/wxsimdem.exe
This is essentially the Build 1.4 posted separately about August 17 or so, except that I had to expand the amount of rain in 30 days (to trigger a message) from 30 inches to 60 inches, because of some users near Houston, where they had up to 50 inches of rain from Hurricane Harvey!
Tom
I get an error when installing - screen shot attached.
Guy
This has also rendered wret.exe inaccessible - it is in the directory but I can’t run the file and cant delete or copy my backup version to the folder. It says I do not have permissions. Using the elevated command prompt to delete the file and restore my backup does not work. Rebooting fixed the issue - but can’t install the new version using the program you provided.
Guy
I had same issue. I never had this before. After rebooting and running it as administrator it worked for me.
brgds,
Oebel
I had no problems and everything is running fine. Make sure all WxSim related programs are shut down before upgrading? Mine is running on Win 10.
  • Jim
Running as admin helped - never had to do that before.
Guy
