You could be right. The only idea I have left is to try an older version of WD. Maybe try build 81 in the new directory with the wd2.txt file. Make sure the name is exact, not wd2.txt.txt (make sure you are allowing viewing of extensions in your file listing).
I suspect some file that WD is attempting to load is corrupted in your wdisplay directory. The month inf file or log file perhaps.
You would need to talk to Brian to find out which file could prevent WD from starting up. The wd2.txt file should bypass all that and allow WD to startup clean, hence the suggestion to double check the exact filename.
I cannot believe this… no warning… just locked up and now it is toast!!!
I really do not want to go back to a really old version of WD. I cannot believe this has happened. Based on my investigation it appears to have blown up at or near 5:17 PM this date as that was that last time the testtags wrote, last clientraw entry etc.
I just do not get this…
Windows is operating fine and I have had no issues with the OS since I rebooted, able to do whatever I try to do. This BOX is only for WD so once it is up and runing I do not go near it for days unless I notice something amiss or I notice a WD software update is available. Other than that, this machine is rarely touched.
Understood, but I had run the latest update a few days back (Friday or Saturday) which was also listed as 56. It was running fine up until about 5:15PM (CST) today. I’m still scurrying around hoping to get this recovered by midnight, but this is not looking promising.
I just completely deleted it again… uninstalled properly.
Now I have a tray icon but no main screen. So I have no idea what it is doing. I tried to click on the tray icon but it does nothing.
As far as troubleshooting that’s all I can think of to try. If the wd2.txt file is used then WD should startup like brand new install. If you have a tray icon then all I can think of is WD is opening off your screen. You would need to search the forum for old posts where Brian mentions the setting that controls that. I’m not 100% sure the wd2.txt file function still works, it’s been a long time since I used it and Brain may have removed it. If that’s the case then I would pull up your ini file in a text editor and see if you can find the setting for screen location.
Sorry, that’s all I can think of to try. Wish you luck in finding the cause…73
OK, well it is showing as b55 which is no big deal. However… no change to my issue.
The Tray Icon loads, NO RapidUpdates or FTPs load… If I force them they will load but since the main program does not seem to be functioning I am sending in old data.
I do get a taskbar icon but it is pure white with the WD logo in the middle of it (most likely the icon loading). Nothing is resolving this issue. Seems something is missing maybe in WinBLOWS? Although I can find no issue with it and nothing reports in. I cannot see any error logs for WD so That is not going to assist me.
try
exit WD via task manager
then run windows regedit.exe
then search for wdisplayftp.ini
in the registry
back that up (export that whole key)
then delete that whole key
then see if WD starts up, as a test
Post deleted - yeah I have to say I was not real keen on doing that but I needed to get it to you if possible. The info@wdisplay email keeps bouncing back to me.
Any chance I can get you to look at the settings and tell me what has blown up? What would you need - not that I am able to give much to you right now since I am running is seriously crippled mode.
I did try to reload the wdisplayftp.reg file from last month and when I do this, it blows up again. Only if I delete the .ini file will it open and run properly.
I downloaded the settings file
WD does run and load (it does take a while as it looks like you have done a lot of customisation), with out any errors, using that setting file
so I cant actually duplicate and fix/diagnose
the only way to find out where the problem is, is to delete sections (save the original) from the wdisplayftp.reg file (open and save with notepad.exe), and reload that into the registry (double click) (deleting the registry entry first and exiting WD first)
that is what I would do to find where the problem is, if I could duplicate here (which I cant)
