Hello,
Where you have to modify it so that the WXSIM part of the saratoga main template comes out in Spanish
Thank you
emilio
I think the issue is with your plaintext-parser-lang-es.txt file – It looks like you have used binary FTP upload for it instead of ASCII. the file on the website is missing NL (\n, x0A) characters at the end of each line, and only has CR (\r, x0D) characters so the script cant use the file.
I’ve processed your file to insert the NL characters in the attached. Download it, then upload to your site. that should fix the Spanish translation issue.
plaintext-parser-lang-es.txt (10.9 KB)
