GFS more than 24 hours old using McMahon data
I have discovered this morning that Chris’ data stopped at 0600 on 23/08/2017. Bohler data is fine which is what I’ve switched to for now.
Same problem here Stuart, thanks for the “heads up”.
  • Jim
I’m investigating. For some reason the GFS product data I read isn’t complete. There should be readings out to 180 hours but there’s only data for the first 24 hours.
Just glad you’re aware Chris, Bohler data is OK so no problems as we can switch for now.
Not sure what’s wrong with the normal data set that I read. My code has the ability to read from two sources, but the secondary source hasn’t been used for some time so it’s needed some tweaking. I’ve done the tweaks that I think are needed and I’m just doing an initial manual run to make sure everything is OK.
I think we’re back to normal now. The import run completed without errors so the 12z data for today (24/08/17) should be available now. The system is back on auto-pilot now so the 18z data should import as normal.
Thanks Chris much appreciated.
Thanks, Chris - as always! :slight_smile:
