import CSV file
Hi, i would like to import the data i have at hand from the Bureau of meteorology website so i have some history on my setup.
attached is a month csv for the local observation place.
http://www.bom.gov.au/climate/dwo/IDCJDW4056.latest.shtml
How would i go about importing this and the other month files.
i have attached a file.
Take that line back, it wont allow me to upload a csv file :confused: its on that page link above anyway.
thanks stu
that data looks to be only daily data (i.e average for the day, max/min for the day)
it is possible to at least get that data into WD for use in the say noaa report
what you would need to do is create that data in the WD logfile, for the month, with the change in day (i.e at least 10 minutes leading up to the change in day (midnight e.g) and a few minutes after (with the correct time and date change in the logfile (in the same format as a normal data) and have the average temperature for most of the 10 minutes but then also have the day max and day min, sort of thing, then use the action, convert WD logfile to data file function in WD
