Evapotranspiration
Hi, I have WeatherHawk weather station and solar sensor. Why this option does not work for me? Thanks!
Is there a solution to see the evapotranspiration value in WeatherDisplay for non-Davis stations?
WD calculates the ET normally from stations that provide solar data
it should at least be doing that
I will see if I can figure out why it is not when I have a spare minute
I currently do not have it where the ET value is requested or used from the weather hawk dll input
Any idea for this?
Sent from my F5321 using Tapatalk
I’m afraid we are all of us who do not have a Davis station in a banana in some way. We are ignored about support, even when we make a donation. This is not right. Data logger does not work, evapotranspiration does not work. There it says that wd supports the weather hawk station. Where is the problem? Thanks!
I finally found some spare time to look into this issue
try the latest .zip update
it should fix it
This is okay now. Thank you very much! :slight_smile:
