Hi, i had everything running ok using Weather34 yesterday but today its decided not to work.
The server is telling my the file as last modified 3 mins ago yet its got the readings from 7hrs ago and the time from then.
Not sure whats going on.
Is there also a tutorial or faq how to setup the clientraw upload only so its doesnt send anything else, also can i pick and choose what i want in the clientraw file.
what is the url to the clientraw.txt file?
what shows in the separate running clientrawrealtimeftp program? (is that running)
and yes you can create a customclentraw
hi,
file location www.frasercoastinfo.com/weatheruploads/clientraw.txt
i did mess around with settings lastnight and it seems to be working again now
Not sure why it stopped though? problem is im not sure what i turned on and off now lol.
Was there a tutorial on setting up clientraw only? I might reset the software and start it again.
not sure what it was but its working now
Ill keep working out that to turn on and off to just have it uploading the clientraw file only with nothing else.
