I am missing some data from Weather Display, it sort of hung today from 5:00 this morning. When I started WD It started to get data from the WMR200 data logger but it thought there was no missing data.
Is there anyway to force WD to download and use the data from the logger?
yes, you can set the time/date to get the data from, under control panel, data logger
but the problem is, the WMR200 only sends the history data once
but you can set in the data logger setup in WD to use the previous history data, i.e to load the wmr200history.txt (after setting the time/date to get the data from)
