Brian,
Any idea what would be causing this error?
Plus I have to go into the taskbar hidden icons and run the mouse over to clear all the running WD cron’s out.
OS: Windows 10 Pro
WD: Ver 10.37S56
Brian,
OS: Windows 10 Pro
WD: Ver 10.37S56
looks like a windows out of resources/memory problem
due to so many of the cron programs running
(not sure why that would be exactly…something wrong with the noaa server for the metar download or your internet connection?)
Brian,
Is this also causing the issue after a while there will be a bunch of the icons in the taskbar hidden icons window. WOW, AWEKAS, WU, Windfinder. I just move the mouse over them and they disappear.
likely all related
something is blocking those programs or similar
-Should I remove WD and re-install maybe?
-Would too many connections to the FTP site cause this?
Thank you for responding…
-Would too many connections to the FTP site cause this?possibly related (ie that then causes other things to fail)
not sure what a remove and re install would achieve
I think I found the problem. It was another program that I use to set all the running programs in specific locations on my monitors. The program is called Actual Tools Window Monitor.
–It worked before I had to start all over. :x
Thanks for the assistance.
