WeatherDisplay Crash every 10/15 min
Hello everybody
This is my system config:
Hw–>MacBookPro retina 15" Late 2013
OS -->macOS High Sierra 10.13 beta 5 (rel.numb.–>17A330h)
WD Release–>10.37 Build 286
Attached to this email log file generated from crash…
WD strats fine and keep running as always … but suddenly after 10/15 minutes it crashes…
(see the log report…for detailed crash informations…)
hope someone can help me to solve the problem… or may be it depends on the OS that is not the final release…??
Thank You in Advance
wd crash report.pdf (121 KB)
do you have the program set to update something on the internet?
it could be that (e.g something set to be updated every 10 minutes)
no I did not set any option… for updating something over the web…
can u tell me where to check … to be sure have no update setting …??
thank you
Marzio
what weather station type?
if you could zip and email me your settings files, then I will check /test here
(WDISPLAY.INI and wdisplayftp.ini)
from
/usr/[yourusername]/Documents/wdisplay/
you should not attach your settings files to a public forum
I did say to email them to me
you should delete them and email me them instead
