I noticed today that my NOAA summary for July shows 0.000" while in fact it was 1.52". I checked further and previous dates in July also show 0.000" now as well, although I remember distinctly that it was showing the running total properly as the month progressed. Also, WD carried over the correct July total to August, showing 1.52" for yesterday and today (until it just rained a little). Can I fix this?
Still using 10.37R build 81.
Bruce
this problem does not occur with the latest version, I think you will find
you will need to set the correct rain total for july under view, rain chart (get that total from the 72017lg.txt logfile)
Thanks. Haven’t been able to get to this yet, will try again tomorrow.
Sorry to resurrect this thread but I’ve had a string of problems that started with burning out my broadband radio receiver power supply thanks to the power surges and outages that probably also caused the WD problem as well.
You mention the newer version – should I apply your fix and then install the most recent version, or install first and then fix?
Bruce
just use the most recent version
