Brian,
(I posted this several days ago on previous threat but I did not get a reply, so thought
perhaps I needed to start a new post?)
Very odd thing happened several days ago. I thought the THDR days thing was solved,
however now it is acting up again. No changes or updates were made since the Build 54
zip I downloaded (which at the time looked like it fixed the problem). The only thing
I had to do since the zip update was reboot the computer and restart WD once for a
Windows 10 update about 3 to 4 days ago. Per previous posts, the THDR days worked as
intended on the 13th and 14th (after I downloaded the zip file) and it kept THDR as posted
on the LCD since then, UNTIL I ticked to add THDR on the 22nd. After the climate ran, I
checked the next morning and found that it had THDR for the 22nd, but deleted the prior
THDR days for the month on the LCD. So, I downloaded the lastest full build (55) yesterday.
I checked the LCD this morning and now all THDR days are gone.
Since this post, I also noticed that after I restart WD, it does not remember the soil
temperature I input manually (which I also do through the Input Daily Weather tab).
Could it be related to my Input THDR days being deleted after a reboot? I would like
to get this rectified before the end of the month if possible. If not before, is there a
way I can manually edited the LCD file.
Thanks for your help earlier this month and thought it was fixed. Any help is appreciated.
Kevin D.
