When I installed WD several years ago I adjusted the barometric pressure readout to sea level in “offsets”. The offset was about +1.5 inches.The adjusted readings were properly reported on WU for years. Recently both the pressure reported on WD and WU went haywire. I again adjusted the WD readings using Barometer “offsets” so that WD showed the correct sea level pressure. BUT then the WU started showing a pressure .117 inches HIGHER than (correct) WD reading.
Now I have adjusted the “Offsets” so that WD shows lower than actual seal level pressure so that WU is reporting the correct pressure.
By the way, I live at 1,200 feet above sea level and the offset when I set up the equipment was about +1.5 inches.
Equipment: Oregon Scientific WMR 200, WD build 54, Windows xp.
Is there something in settings that I am missing?
