Bohler GFS back up and running
Bohler data is back up and running! :slight_smile:
The problem was that the GFS upgrade added a new data type, that squeezed in between existing ones and bumping some of our data over by one. Sam has not only fixed that particular case, but has changed the way the data is “anchored” so it should NOT happen again if there is another upgrade of that type (i.e. with new data fields added).
Tom
Tom,
Looks good. I got a clean WxSim run with WxSim-Lite and Bohler data. Thanks to you and Sam for a quick fix.
Steve
See other thread about GFS data. My lite data is bad again at 00Z 21st.
wxsimlite:
2017-07-21-00 run with bad Data
last good run was 2017-07-20-18
The Rest seems to work with Bohler
Hi Tom,
Everything works here after three updates again normally without error messages.
Thanks to you and Sam,
Piet
My morning WXSIM/WXSIM-LITE forecast ran with no problems.
James
