I’m not as familiar with Windows as I used to be years ago and I’ve obviously clicked something regarding the internet access for the FTP uploads from the WD (its external .exe files). I have a wired Eth connection. Yesterday I enabled the WiFi and connected to my home WiFi network (wanted to try something). That’s when I clicked this.
Now the clientraw and normal FTP uploads do not work anymore. WU rapid fire updates as normal (I might not click anything there).
This is what the FTP log outputs:
Connecting to FTP server.
OK
Connected.
220 Xlight FTP Server 3.8 ready...
USER <my_user_name>
331 Password required for <my_user_name>
PASSWORD=****
230 Login OK
TYPE A
200 Type set to A.
CWD /
250 Directory successfully changed
Uploading file C:\wdisplay\webfiles\clientraw.txttemp -> / clientraw.txt
PORT 188,230,241,88,228,96
200 PORT command successful
STOR clientraw.txt
150 Opening ASCII mode data connection for clientraw.txt.
Reseting the FTP, inactive count exceeded
ABOR
***143: Busy performing current action.
Reseting the FTP
Reseting the FTP
301: Interrupted.
QUIT
OK
Disconnected.
301: Timeout.
File uploaded at time :7:14:8
Uploading file C:\wdisplay\webfiles\clientrawhour.txttemp -> / clientrawhour.txt
OK
Connected.
USER vremetolmin
PASSWORD=****
230 Login OK
TYPE A
200 Type set to A.
CWD /
PORT 188,230,241,88,228,107
STOR clientrawhour.txt
150 Opening ASCII mode data connection for clientrawhour.txt.
Is the problem indeed a blocked internet access for the FTP executables or is it something else?
