I have been having a go at setting up a weather station on my raspberry pi3 using this link http://trastle.github.io/rpi-weather/gettingConnected.html.
I connected the Davis Vanage Vue to the raspberry pi and tried this command, python ~/weather/pywws/code/TestWeatherStation.py, but it didn’t run as there was no file called TestWeatherStation.py
Anyway,I moved on to the next step of running these commands:
wget https://raw.github.com/trastle/rpi-weather/master/udev/38-weather.rules
sudo mv 38-weather.rules /etc/udev/rules.d/.
sudo /etc/init.d/udev restart
Afterwards I couldn’t see if the Davis station was being recognised or see by the raspberrypi, and reconnected the Davis station to the windows machine which has WD on.
Now WD cannot get the data from the Davis Vanage Vue. Have I borked it or is there a fix.
