I am using a WeatherHawk 916 and WD is picking up the data from its IP server as set in the WD Station Setup screen. The fields are described in the setup portion and I have no field setup for UV (no sensor).
However, in the string that is loaded to Meteotemplate via the built-in API, a value/field of zero (0) for UV is loaded up, which in turn has meteotemplate publishing such (0) as a live value.
Hopefully between Brian and Jachym, a solution to not upload or not publish a non-existent sensor value is possible.
do you have solar (wm/2) data though?
I have added where you can set to send solar or uv to the MT setup in the latest .zip update
Thanks Brian, but it still shows UV:0 and UV time near the end of the string
meteotemplateLive.txt (686 Bytes)
you can see what WD is sending
in the file
sentcustomhttpget.ttx
and so see if the uv data is being sent
