I’ve tried all the different way on how to correct rain total for a single day without success. For some reason WD does not save the changes no matter what I try. Followed the FAQs, tried to convert log and data files and been reading posts here. What am I doing wrong? Currently on 10.37S54 and the log file has correct values. The daily reset was not performed due to an upgrade between the 8th and 9th though.
so following the youtube video on how to edit daily rain totals did not work?
if you could .zip and email me the current month data file and log file and I will test here
@ Matrix, if your may log file is OK, then try converting that log file to data file
@ Labbs
the problem is there is too much missing data in the log/data files
i.e
8 7 2017 18 38 17.5 72 12.4 1009.4 8 10 259 0.0 0.8 6.0 327.0 17.5
9 7 2017 1 39 17.5 72 12.4 1009.4 0 0 273 0.0 0.8 6.0 327.0 17.5
what you need to do is add in enough missing data in the logfile, around the midnight reset period, and with the needed daily rain reset, and then convert that logfile to data file
i.e you need a few minutes prior to and including midnight change over and a few minutes after midnight (e.g 10 minutes either side).just use copy paste of a line of data and then edit the hours and minutes and day
