Hello all
Since a few days
I can have the menu FTP
do you mean it will not open in WD ? (control panel, ftp/internet setup)?
Hi Brian
yes i can not open it
all de rest i can open
Greetings Dirk
try
find and delete the settings
[Main FTP setup]
last FTP setup left=
last FTP setup top=
in the wdisplay.ini settings file,save, when WD is not running
Hi Brain
this is not working
still the same problem
Greetings Dirk #-o
the best thing is to .zip and email me your settings files (see the FAQ)
but also is there any error under view, program event log, when you try to open those settings
Hi Brian
yes in the View there also buttons that no longer work
AVERAGES/EXTREMES NOAA STYLE Reports
LIGHTNING COUNTS etc
ERROR: Access violation at address 67BDDF8D in module ‘RICHED20.DLL’. Write of address 00000001 System.SysUtils at time/date 9:50:46:6 12/07/2017
Error reading logmemo3.Lines.Strings: System Error. Code: 1400.
Invalid window handle
ERROR: Access violation at address 67BDDF8D in module ‘RICHED20.DLL’. Write of address 00000001 System.SysUtils at time/date 9:57:28:56 12/07/2017
ERROR: Error reading RichEdit1.Lines.Strings: System Error. Code: 1400.
Invalid window handle System.Classes at time/date 9:57:28:71 12/07/2017
ERROR: Access violation at address 67BDDF8D in module ‘RICHED20.DLL’. Write of address 00000001 System.SysUtils at time/date 9:57:36:458 12/07/2017
Invalid window handle System.Classes at time/date 9:57:36:468 12/07/2017
ERROR: Access violation at address 67BDDF8D in module ‘RICHED20.DLL’. Write of address 00000001 System.SysUtils at time/date 9:59:58:617 12/07/2017
ERROR: Error reading logmemo3.Lines.Strings: System Error. Code: 1400.
Invalid window handle System.Classes at time/date 9:59:58:622 12/07/2017
ERROR: Access violation at address 67BDDF8D in module ‘RICHED20.DLL’. Write of address 00000001 System.SysUtils at time/date 10:1:56:10 12/07/2017
Invalid window handle System.Classes at time/date 10:1:56:15 12/07/2017
ERROR: Access violation at address 67BDDF8D in module ‘RICHED20.DLL’. Write of address 00000001 System.SysUtils at time/date 10:11:1:975 12/07/2017
Invalid window handle System.Classes at time/date 10:11:1:978 12/07/2017
ERROR: Access violation at address 67BDDF8D in module ‘RICHED20.DLL’. Write of address 00000001 System.SysUtils at time/date 10:11:11:418 12/07/2017
Invalid window handle System.Classes at time/date 10:11:11:418 12/07/2017
I do not know what happened , i will sent you the files
Greetings
Dirk
I was away this last few days
those errors look like a problem with the windows richedit system
if you sent me your settings files…if you could email me them again…
