Hi eveyone and body,
Not found on this board…
Could someone provide name, tags of all time records which may be
viewed in “View/All time records”
Thanks, regards.
-= Guy =-
Thanks, regards.
-= Guy =-
do you mean custom tags, as per what is shown in the file tagslist.txt , in the section, all time records?
Brian thanks for the answer,
I would like to display on my site a page with all the records up to date.
As seen on the WD page: “View/All time records”
Meaning using the vars in testag.php or any one to be added in the custom tags
in testag.txt
Thanks, regards.
-= Guy =-
does this sort of thing work for what you need?
http://www.weather-display.com/windy/gb/alltimerecords.html
That is exactly what I would like, but having the var names for that.
They should be ??? in testag.php or or a customtestag file.
Thanks, regards.
-= Guy =-
That is exactly what I wanted,
Thanks so lot , regards.
-= Guy =-
but that was the info I provided in my first post
i.e
do you mean custom tags, as per what is shown in the file tagslist.txt , in the section, all time records?:wink:
