In the control panel ‘Email Warning Setup’ under the ‘Custom Options/All Time Records’ tab I have setup to use a custom file (customemailwarning.txt), use html formal and use a custom subject. My customemailwarning.txt is formatted in html.
When I test the custom email or a weather warning threshold is detected, the email gets delivered however the email client displays the raw html i.e. it doesn’t render the html page as expected. I am using html formats for my daily and weekly weather reports and I am confident the html is formed correctly.
I was just about to write a post, good job I searched 1st,i too have been trying to figure this out since I had a 2mm of rain warning, it came through as just tml code
Somewhat related to this thread, does anyone know what tag I use to report the trigger for the weather warning e.g. maximum wind speed, etc?
I have tried the following:-
%current alarm flashing% always seems to reports “—”
%warningemailalarm% always reports " - Warning on 6/7/2017 14:20 (Day)"; this output is directly related to the ‘Custom Subject’ set in the Control Panel → ‘Email Warning Setup’ window ‘Custom Options/All Time Records’ tab which I have set as “- Warning on %date% %time% (%dayornight%)”
Maybe what I am trying to do is not possible, however I thought it would be as I assumed the default weather warning setup would use a similar approach using tags. Or, is the Custom Subject working/not-working?
Thanks for the confirmation.
Do you know of any method I could use to report the weather warning other then the default email e.g. is there a file I could append?
simply put that info in the custom email (i.e as text), I would have thought
ie what your thresholds are for the warnings you have enabled, or something similar?
Yeah that is an option, which I might go with.
I was wondering if I could attach like the daily hi/lo table or something similar such that the email receiver has knowledge of sensor readings. Although I can’t see a way to generate a internet file creation on demand apart from the scheduled generation/upload times configured, so unless this file is generated frequently there would be no point.
