I am having a problem with my logfile converting.
It will only convert the first ten days of June correctly.
The logfile looks ok to me but if I load the file to check alignment this comes up.
It is putting 25 in front of each line from 11-6-2017 11:46 onwards.
Different numbers on other lines.
Here are last entries of today.
What can I do about this.
TIA
#-o
Problem solved.
Took another look at the logfile, seems there was a zero to many on line 11 46. #-o
11 6 2017 11 32 25.1 58 16.2 1014.0 3.3 5.2 233 0.0 0.0 40.6 245.0 25.1
11 6 2017 11 46 25.1 58 16.2 1014.0 2.0 6.0 240 0 0.0 0.0 40.6 245.0 25.1
11 6 2017 11 47 25.0 57 15.9 1013.9 0.7 7.0 247 0.0 0.0 40.6 245.0 25.0
nog een heel karwei om daar achter te komen…
You easily overlook that extra zero and that’s what I did.
But it had something to do with line 11 46 because that’s where the alignment went wrong.
