Hello, my soil moisture is at 200 (0%) due to a lack of rain, the vp graph soiltempmoistrain.gif hit 200 then dropped off back to 0, even though the soil moisture is still at 200 as seen in the advanced graph.
What shows on the VP2 console for your soil moisture and also in WD>View>Davis VP/Vue Extra Sensor Info? Do both show 200?
It’s also handy to know the WD version & build you’re using.
Hi, its the latest build and that bottom graph is from the WD>View>Davis VP/Vue Extra Sensor Info as you can see, the graph said 0, yet the reading in there said 200, Console said also said 200 as did the soil tag
I did not allow for 200 or above (did not think it would get that high)
try a new .zip update
Thank you, although it could be a while before it reaches 200 again, but i will let you know once it does, thanks again.
