Moved to New Computer, Web Graphs Truncated on Right Side
I just moved weather display to a new computer and the web history graphs gifs are truncated on the right side. You can see it here http://weather.douglasjohnson.org by scrolling down a bit. They worked fine on the old computer (Windows server 2012), but I’m having this problem on the new one (Windows 7). It is clear the gifs are being truncated before they are uploaded. I am using an old version of weather display, version 10.37R, but it has always done what I needed.
Any suggestions would be appreciated.
Doug
try
go to setup
advanced/misc
main program customise
tick enable
then go to view, graph history, and make the graph window a bit wider
then go back to above and click on save
the problem also could be related to the windows desktop screen resolution and if set to use large fonts
That worked. Thanks.
– Doug
