I can’t figure out why WD closes down up to twice time a day.
I’m getting a message from "Weather underground: Oh no, your station stopped sending us data on May ??? and I can see that WD is not running.
Is there a log file that shows why WD closes down, or one in the group that can answer it?
Other running programs on the computer, still running, only WD is closed.
Se attached picture
Have a look in programerrorlog.txt in the wdisplay directory on your PC - any errors shown? (resetting warmest day are normal messages)
There isn’t anything from the 15/05/2017 until today ?? This I the last lines in the file !
Can "Write to logfil2 be disable, since there isn’t for the last days ?
From the fil:
error with create file 2 Access violation at address 01E85315 in module ‘WeatherDisplay.exe’. Read of address 00000420
Above error or program log occured at :22 15 02 15/05/2017
error with new custom string 6b Access violation at address 022892ED in module ‘WeatherDisplay.exe’. Read of address 00000454 %hddyear% testtags.txt
Above error or program log occured at :22 20 02 15/05/2017
error with new custom string 6b Access violation at address 02287C61 in module ‘WeatherDisplay.exe’. Read of address 00000454 %cddday% testtags.txt
error with new custom string 6b Access violation at address 022884A1 in module ‘WeatherDisplay.exe’. Read of address 00000454 %cddmonth% testtags.txt
Above error or program log occured at :22 25 02 15/05/2017
My “Main log Settings” - anything I have to change ?
which version/build of WD?
it looks like you are getting an error every 5 minutes with a custom tag update
so that is a clue
