hb1wirereader
Hb1 wirereader program after loading does not want to load my 1 wire lightning and humidity sensor automatically after restart, but i have to click find sensors for it. How to solve this problem?
have you ticked that you actually have those sensors?
It looks like this:
I see you have ticked enabled for the first temp/hum ROM ID
but you don’t have that filled in, but instead are using the older hum type
that might be an issue
try unticking that
I should type the value for the first temp / hum ROM ID similar to the older humidity. It looks like it will be okay now. Thank you, Brian.
