Possible to use remote Temp/Humidity station instead of ISS T and H?
Hi Gents,
My VP2 is roof-mounted, and my new shingles are driving the daytime temperatures a few degrees higher than normal. Is it possible to use a remote T/H station unit for my primary T/H sensors and disable the ones in the ISS?
Thanks for your help.
are you talking about in the weather display software?
Sorry that I was not more clear. I want to use a physically separate temp measurement sensor (placed at some distance from the ISS) and have the remote temp station be the primary temperature measure for my station. Thanks!
as in WD use that sensor for main outdoor temperature?
Roger that. Temp and humidity, if possible. Got solution?
THANK YOU!
I think this is the WD solution you are looking for but Brian can correct me if I’m mistaken.
Actually found another setup page that looks like it would include temp and RH.
yes , that is the one (second screen shot) :wink:
