Brian:
Since May 2…my forecasticon5day1,2,etc. gifs have not updated. My forecast5daygif has the correct icons. I use the forecasticon5day1 thru 7 to populate my carter lake section of my WD page…
http://weathership.com/wx4.html
Any thoughts?
ohz055.txt (1.69 KB)
is the actual modified date/time on those files up to date?
I see the problem , problem occured when I added support for the new API (which everyone will need to change to once that is finalised, as it sounds like the current method will stop being updated (the file downloaded)
use a new .zip update of WD
Thanks Brian…Ill do this after work…Also, once the new API is being used in WD, will the 5 day (graphics, icons and text) display and behave as before? Or will those go away?
should all work as before
OK Brian…Icons all set now…many thanks…Pardon me for sneaking in a NWS API question…What is the proper format for entering lat lon in the API area of WD?..are the two values separated by just a space or some other character? (Comma, etc)… I assume that west lon would be a minus sign, too? …I inadvertently erased your default values to test.
TS
I do have an example default format that works…follow that.
38.96,-94.62
dont have any more than 4 decimal places
