seems to be a bit of confusion here between needing to know the version of the separate HB 1 wire reader and or the version of WD?
the HB 1 wire reader does have provision for a lightning counter ROM ID
do you have that setup and does it report that its found it etc, and then also make sure you have set in WD, in the 1 wire setup, that you have a 1 wire lightning sensor
