I am hoping someone can point out the error of my ways but no matter what I try I simply cannot get WD (v10.37S Build 33) to create the customclientraw.txt file.
The customclientrawlocal.txt file is located in the C:\wdisplay\FTP-EXPORT which has been setup in WD
I have created a folder located n C:\wdisplay\FTP-EXPORT, then set the config for WD to point at this folder and then have followed the various posts / videos etc for configure the realtime ftp and the net result is:
FTP upload is working
clientrawdaily, clientrawextra, clientrawhour are all created and updated based on the update times set
I have attached various screen shots, I hope someone has some advice.
I see that you have windows set to hide known file extensions in the windows folder options
unset that
as you maybe it called customclientrawlocal.txt.txt or similar
also make sure that WD is pointing to the correct folder, via setting the webfiles folder, in the webfiles/web page setup
If I go to WebFiles/Web Page Setup → Custom Web Page Setup/Meteotemplat.com and hit the Test button the file is indeed updated it just does not do it by itself at a pre determined time i.e. evey mintue.
