as explained in my post above, for the WH3081 station, WD has to read the data from a different memory address on the console, to normal weather data
sometimes that will get out of sequence and so bad data will be returned
(what I need to do is check for the data being bad, e.g check on date or times in the data), so as to ignore that data
so trying to use a WH3081 station with the WD software to show that the davis solar glitches are not real etc is not really going to work
I would instead be using the cumulus software for both
I have though made WD ignore glitches in the data at night for the WH3081 station in the latest update of WD
