Hi all,
Almost everything is running fine here except for one thing. Sometimes the rainfall curve does not reset to zero at midnight. The curve does not drop to zero whether or not rain hasn’t fallen for a while or it’s continuing to fall. It seems to be happening randomly. This is occurring in Build 285 and has been in at least the last few Builds. Anybody else experiencing this? By the way Brian, it’s nice to have the time tics on the graphs again. Thanks for that.
Aloha,
Mark
so WD is running at midnight?
any errors under view, program event log, around that time?
what weather station type?
if a davis station, do you happen to have set to use the davis console rain total? if so then make sure the time/date on the console is set correct
Wanted to see if it would reset. Finally did last midnight after rainfall accumulation had been tracked for the last few days. Error message (and there was a long list of it repeating) is “Request aborted on timeout”. Davis VP2, time is running about 1 min ahead of computer clock. WD clock stalls but jumps to catch up every 1/2 min or so.
