I have been puzzling over this missing data for a while now.
Can anybody tell me how I can get to see the values?
Can it be reset back to default in case I messed it up?
Image below.
Image below.
which version/build of WD?
10.37S42
Win10
VP2 + Solar
you could try:
run windows regedit.exe
search for wdisplayftp.ini
then
[broadcast custom]
labelhightemp x
and make that value bigger (and same for labellowtemp x), e.g to 100
Hello,
I see that questions of this problem is increasing, I would like to ask what you think about the thread on which there was no response.
Thank you very much.
Thanks Brian. That worked. Both my settings were 12 - now changed to 100.
I just need to adjust position now which I will do later.
@Matrix
I cant really make out what exactly is wrong in that post/thread you mention
its not very clear to me
That must be clear if you look at the pictures in the link.
Predictive text summary gif using the client repeats behind.
The second picture shows a summary gif where there is a station that’s fine.
not sure what Predictive text summary gif using the client repeats behind means, sorry?
WD Brian, worked for me also (same situation, both x setted to 12 ad updated to 100)
