Hi all. I have a new website specially for weather and I have set up WD ftp to transfer my data. It seems to upload fine but I cannot see anything at all on my new website and then when I go in to ‘web files/web page setup’, I click on ‘View a webpage’ and there it is.
What am I doing wrong???
I’m afraid I am not very technically minded so I appreciate any help …Thanks
what is the URL to your web site?
and what shows in the ftplogfull.txt file?
You might want to edit your last post and remove your password from each of the two long links.
which version/build of WD are you using?
the best way to get files to your web site is to use the customise internet and file creation setup
I have a youtube video outlining how to use that
hi. i’m using Ver.10.37s41. I am using the pages you suggest but nothing appears on my website… i’ll look at you’re videos and let you know.
thanks.
is the main internet switch on in the connections setup?
also make sure you have ticked their to use WD’s ftpupd.exe program
the main switch is on. i cant see the ftpupd.exe. i have ‘Use Weather Display’s own FTP’ ticked.
does the ftpupd.exe program exist where WD is installed?
if you could .zip and email me your settings files then I can check on them
yes it does and I can see it uploading on my desktop.
what I mean is
does it show that the files on your web page are uploading?
is the remote directory set correct in WD?
Hi, if files are being uploaded you should see details of FTP logging into the server and transferring files in ftplogfull.txt
e.g.
Logging onto FTP server…<ftp.yourservername>
Connecting to FTP server.
OK
Connected.
220---------- Welcome to Pure-FTPd [privsep] [TLS] ----------
220-You are user number 5 of 500 allowed.
220-Local time is now 10:10. Server port: 21.
220-This is a private system - No anonymous login
220-IPv6 connections are also welcome on this server.
220 You will be disconnected after 15 minutes of inactivity.
USER=****
331 User OK. Password required
PASSWORD=****
230 OK. Current restricted directory is /
TYPE I
200 TYPE is now 8-bit binary
Checking for next FTP agenda…
there are 2 more things to do
Doing ftp upload
Checking there are files to upload
There are more files to upload
PASV
227 Entering Passive Mode (91,121,173,32,237,151)
150 Accepted data connection
226-File successfully transferred
226 0.016 seconds (measured here), 300.47 Kbytes per second
PASV
227 Entering Passive Mode (91,121,173,32,194,183)
226 0.021 seconds (measured here), 360.50 Kbytes per second
PASV
227 Entering Passive Mode (91,121,173,32,247,26)
226 0.000 seconds (measured here), 2.05 Mbytes per second
PASV
227 Entering Passive Mode (91,121,173,32,232,49)
etc etc etc
your log just shows data being transferred to Wunderground (more than 2 years ago so it may not have been updated since)
Best thing is to zip and email settings files to Brian so he can check. (In WD, action → backup windows registry entries, then look for wdisplay.ini and wdisplayftp.reg in c:\wdisplay\databackup - those are the files to send)
Sorry about that. I have the remote directory set correctly, as far as I can see. my website url is http://vincentlong.info/
list of files uploaded*
Start Time/date:21:00:58 13/04/2017
Permanent connection selected
Finshed email agenda
Finshed email agenda, and more Internet agenda items to do…
Weather Display FTP/Internet vers 9.03
Time/date:21:01:00 13/04/2017
Logging onto FTP server…gator4076.hostgator.com
OK
Connected.
220-You are user number 10 of 150 allowed.
220-Local time is now 14:00. Server port: 21.
USER=****
331 User uinsinnl OK. Password required
PASSWORD=****
530 Login authentication failed
OK
Disconnected.
141: FTP protocol error: 530 Login authentication failed
Change to remote Dir /home3/uinsinnl/public_html/
This is the latest logfile. The fact is that the highlighted files do exist
Start Time/date:17:54:06 14/04/2017
Time/date:17:54:08 14/04/2017
OK
Connected.
220-You are user number 2 of 150 allowed.
220-Local time is now 10:54. Server port: 21.
USER=****
PASSWORD=****
TYPE I
Change to remote Dir /home3/uinsinnl/weatherdisplay
CWD /home3/uinsinnl/weatherdisplay
550 Can’t change directory to /home3/uinsinnl/weatherdisplay: No such file or directory
141: FTP protocol error: 550 Can’t change directory to /home3/uinsinnl/weatherdisplay:
there are 1 more things to do
Doing ftp upload
All Agenda complete, doing FTP log off…
FTP logoff
QUIT
221-Goodbye. You uploaded 0 and downloaded 0 kbytes.
OK
Disconnected.
221 Logout.
550 Can't change directory to /home3/uinsinnl/weatherdisplay: No such file or directory
try putting a trailing / on the end of the remote directory
are you using the customise intenet and file creation setup?
if you are (recommended) then make sure you have set times to create and set times to upload, the files needed on your web site and you have the switch on in the create and in the upload times
and the override switch is on
Remote into your server from a terminal and issue a pwd command and see what it reports as your root directory. If it shows you’re root is /home3/uinsinnl then drop that part from your WD setup and just ftp to /weatherdisplay.
