While the VWS CSV import routines work very nicely (thank you very much!), I have noticed that at the top of the screen the target folder and filename are partially covered by the box that shows the progress of the import process - see the attached image capture for clarification.
This isn’t anything big but something that I thought might be addressed as a non-critical issue.
Thanks for all you do Brian!
EDIT: Forgot to add my sytem info and WD version info…
Thanks Brian. I wasn’t complaining. Just thought it would be useful for others.
BTW, thanks to several of your WD import utilities, I have finally brought my wx history files up-to-date after a two-disk failure last December that wiped out my live data as well as my backup datafiles. I had a mix of both WD and VWS data archived and have now completely switched from VWS to a 100% WD driven weather package.
I’m still rebuilding my website and getting everything running again. It’s taken months due to the limited amount of time I have to work on such things.
