Run A Program - Tide Graph Generation
WD Ver10.37S45
I have added my local tide graph image generated from wxtide to my WD main window and I wanted to update the graph hourly. To do this I thought I would use the Internet Settings > Manual Upload/Run a Program (see attached screenshot) by running the runtide.bat file at 59mins past every hour. It works if I press the ‘Run now’ button, however it never works for the times configured.
To verify this behavior I made a test batch file that logged the date and time stamp in a text file as follows:
echo %date% %time% >> test_timestamp.txt
I ran this for a few days and the results were the same i.e. worked when pressing the test button but doesn’t work with the configured times.
try this test version
Ok its running and configured with my test script, I will let you know the results tomorrow.
Yes, it is now working with the configured times thanks.
