the graph component decides auto if there is room to be able to put the label between the time stamps or not
(the vertical line is still shown, showing the time)
if you reduce the font size of the time for the graph, that should help
So why has it worked OK(-ish) up to now? It’s never “decided” to change this fast before.
And does it also “decide auto” whether to put the Moon rise/set labels above or below the time axis? When it puts them below, it conflicts with the times.
And there never has been a vertical line “showing the time” for the Moon rise/set. . . that’s why it’s so frustrating. If there were lines I think I could work it out without labels.
And, as you know, I run a 20% larger main screen so I cannot save e.g. font size changes without resetting the screen size (See last two posts at http://discourse.weather-watch.com/p/494885). Then, when I set screen size up 20% from normal again, the scaling-up doesn’t always work with font sizes.
before I updated the graphing component (to see if there was a fix for an issue with the missing times on the Mac version, which has not been fixed yet), the label would not show in the time part
but they must have changed something with the graphing component
as I have already stated, its all done by the graphing component
and its out of my control
I did update the graphing component, as I needed, due to no time labels showing for the OSX version of WD, and that update has made a change in this behaviour
you could always use the older version build 42 if it really is that big of a problem for you
Sorry, I was just winding you up after your suggestion to go back to S42 - if only for a day! I’d already written the labels off, because you said it was beyond your control. Good to hear there may yet be a solution.
