Hi, I’m using Murry’s (Wildwood Weather) stats script and am having a problem with the rain totals for 1 day. On March 14, it says my station recorded 2,743.2 mm of rain, when in actuality, we only received 25.5 mm. Can someone tell me how to correct this?
you need to correct the data in WD
that is where it is coming from
there is a FAQ on how to edit the daily rain totals, as well as a youtube video http://www.weather-display.com/youtubevideos.php
In WD, go to View>Averages/Extremes/NOAA Style Reports. Select the second tab from the left - NOAA Style Reports.
Enter 3 and 2017 as the date to calculate, then click the Update whole month now button.
If the data is correct, click the Update dailynoaareport.htm button. WD will then create and upload an updated dailynoaareport32017.htm file.
But it will also upload an updated dailynoaareport.htm which is a duplicate of the dailynoaareport32017.htm file so the April data displayed by the scripts will be incorrect.
So either wait until after midnight tomorrow when the April data will be updated. Or enter 4 and 2017 as the date to calculate and follow the same steps as for March.
That did it, thank you Murry! I suppose it would also have worked if I’d followed Brian’s advice and waited overnight, but I’m the kind of guy who likes results NOW! LOL!
