No idea what it means, or how to fix it.
PLS help
http://dayboroweather.com/wxsim-error-9.jpg
Nobody?
I have removed old forecasts.
Done pretty much everything I found in other posts… got me stumped.
Scheduling atm:
WXSIM-lite starts one hour before WXSIMATE
WXSIM-lite hour to run analysis (once per day) runs at 01:30
WXSIMATE starts 15 minutes before WXSIM
I do not use Weather Display but I think I have gotten a similar error message when my local data provider file was corrupted. You might try renaming 32017lg.txt and see if it rebuilds and clears up your problem.
FWIW
George
Thanks George.
I have tried that, the moment there is no 32017lg.txt file it all works fine, but the moment WD writes/creates that file things fall over again…
It actually creates more Error 9 messages.
#-o
It could well be bad lines of data in that log file. I’ve certainly seen examples of that before. Can you send me the file, and also tell me as accurately as possible just WHEN the problem first appeared?
Thanks!
Tom
Tom,
Thanks for the response, I deleted the offending file out of wxsimlitedata directory… seems to work ok now… (fingers crossed).
=== Edit ===
I think this is working now.
