WMR100N wind speed and direction stuck
Some time ago my WMR100N console lost communication with anemometer and a value of 35.2 km/h and north direction were stuck in WD wind dials (in console were dashes --). Today I’ve replaced new batteries and reset it. The console now shows right values and when I open WMR100.exe it shows:
Battery status wind 0
Gust speed= 1.5 m/s dir 158 average 1.9
temperature found, sensor # 0
Indoor temp =24.4
Indoor hum =28.0
Indoor temp =24.5
Indoor hum =28.0
Gust speed= 1.5 m/s dir 158 average 1.6
console found
baro found
Forecast icon 0
** barometer = 1016
rain found
rain =0.0 mm
Gust speed= 1.7 m/s dir 158 average 1.6
Indoor temp =24.5
Indoor hum =28.0
temperature found, sensor # 1
outdoor temp =24.3 sign raw 00
outdoor hum =23.0
It seems to work fine but wind speed and direction are still stuck in 35.2 km/h in WD. I’ve reseted console and it’s still the same.
Any solutions ?
I’ve updated WD to the last versi
WD should now be getting the correct live windspeed data for the current conditions area
especially if you have restarted WD
I’ve restarted Windows 10, WMR100N console and WD several times. Still stuck at 35 km/h. All of other values are updating fine.
that is odd
if you could .zip and email me your settings files
(see the FAQ)
but maybe you had set WD to use the windspeed from a metar
Exactly :smiley:
I had ticked wind/direction from metar.
Thanks for the clue
Best regards
