Hi!
Can anyone explain why there are values in temp / hum exstra 3 and 4
See picture.
I’ve set up something wrong?
Temp / hum extra 1 is the only extra I have.
Torjan
Hi!
See picture.
Torjan
Hi!
A more detailed explanation.
In the work of updating meteotemplate to use API, it has appeared a few things about values of individual sensors.
For the new API to work properly, these mistakes should be corrected.
Have a value extra humidity sensor #4 I do not know what is and extra temperature sensor #8
Have extra temp/hum 1 and soil/moisture 4 temp and 4 moisture sensors and 1 leafsensor.
in clientraw.txt file it is the no 121 and 122. Taken out of clientrawparser it looks like this.
120
extra temperature sensor #7
temperature extra
-100.0
not sure what you are trying to get across here?
I think he wants to know where the data is coming from for 3 and 4, 4 to me looks like solar and 3 could be outside temp??
if he means he does not actually have those sensors
then try deleting the entry in the wdisplay.ini file, when WD is not running
[last extra temp]
value 3=
etc
Hi!
Beginning to figure out where the values come from. appears as soil values.
see picture of setup. Is this the right way to set up?
Torjan
Hi!
Now there are only two values left I wonder what is.
in clientraw.txt
021 temp extra_sensor 2 255.0
and
122 humidity extra_sensor 4 0%
Where do these values come from?
Torjan
255 is a default value
I will make it so that if that value comes through, its not sent to meteotemplate, for the next update of WD
(and same for 0 for extra hum)
The 122 humidity extra_sensor 4 does not always have 0%
can it have somting with solar/uv.
Found this in the setup for solar.
Hi!
After some comparison think I’ve figured it out
When humidity extra_sensor 4 shows 8%, it means that we have uv 0.8
Is that correct?
