I’ve added several custom tags to the “current conditions”-area. Sadly it’s only possible to have 8 tags… so I only can add 4 values… because one tag is for the description and one for the value.
I’ve seen that more down in the menu there are 18 more tags possible, BUT these will schon in the “time”-area. If I try to move the custom tag from the “time”- to the “current cond.”-area, the tag will be in the background from all other areas - only in the “time”-area it will be in de foreground.
Is it possible to move it to other areas and set it to the foreground, so it is vissible?
