Clientraw.txt info
Is there a list/guide that view how Clientraw.txt is structured and what the individual values is meaning ?
clientrawdescription.txt is part of the install package and should be in the folder where WD is installed.
You misunderstand me. I need to know what each value represents. - See picture
http://imgur.com/a/YiIeV
Niko has given the answer to your question
If you look at clientrawdescription.txt it should answer your question :? That file lists the parameters in the order they are in the file and tells you what units are used for each one.
There is also Clientraw - Script developers info
Add the location of your clientraw in the selection box http://www.steenmikkelsen.dk/vejr/webfiles/
It displays the contents of your file, a description and the units used for every field in the 4 clientraw files.
There is a cross reference of the 4 files.
This lists all data types with field-numbers at Xref Clientraw - Script developers info
There in Weather Display can I enable “temp extra_sensor 2” - se picture
I have 4 sensor Total outside.
what weather station type?
Ventus W928 Ultimate - Clone of Irox station
I am not sure why extra temp 2 is not coming through correctly
what version/build of WD?
the newest from mar. 15. 2017
I allway opdate to the newest then you opload one.
what shows in the separate running irox data program?
I do not know what it is you ask about - please specify it?
it should be running in the system tray
Taskbar - se picture
