MeteoTemplate API data updating - Resolved
ver 10.37S43 full install (with later zip added)
The meteotemplate is uploading at the one minute rate that I initially set. The database is updating every 5 minute without the cron job. But I cannot get work properlyat the 5 second rate. I have tried deleting the information in the meteotemplate setup setting to off and exiting WD. Restart WD, enter info, setup to 5 seconds, turn on. Restart WD.
The data (wind speed & direction) on steeelSeries block and plugin, current block, and gauges block will remain constant for one minute, however the time display will advance every 5 seconds…
I have added the meteotemplate API to wxstatus.php (10th item down) and the file is updating every 5 seconds (click on ‘Refresh Status Data’ to confirm)…
but the not the content, other then the time, is updating at one minute rate.
Gus
Question for Jachym…
After selecting api in the setup menus, should the path to file be left blank?
yes, I see now, that I am using 1 minute average
but if the update rate is faster than 1 minute then I need to be using current data instead
I will get a new update up of WD to resolve that
great, thanks
ok, build 44 .zip update ready
and also now the gust data is the max windspeed since the last api data update too
Downloaded bld 44 zip file
Now seeing the upload problem described in this thread…
http://discourse.weather-watch.com/t/63749
No auto load and manual test/update may work once after WD restart.
*** Inconsistent may or may not show success box.
Gus
not sure what you mean by success box?
I am using build 44 with 1 minute update OK
http://www.weather-display.org/template/indexDesktop.php
what is now your current update rate?
5 second selected
Bld 44 selected one minute and it is auto and manual uploading. But not at 5 sec.
** Tried every 30 second -also did not work
one minute is the only working selection now
the auto data update (any update rate) is sent via the cronhttpget.exe
what shows in the file
sentcustomhttget.txt
where WD is located
when 5 seconds is used
1 minute selected
OK
OK
5 seconds selected
OK
Bad Request
151: HTTP protocol error. 400 Bad Request.
The sentcustomhttget.txt file is being updated every 5 seconds
what I will do is log to that file what was actually sent
but it could also be that the 5 seconds might be stomping on each other
i.e try testing the every 30 seconds
30 seconds selected
OK
Bad Request
Delete the sentcustomhttget.txt file and it is created every 30 seconds
I think I know what is wrong
especially if you were restarting WD after setting to 1 minute
standby
(been a bit distracted as I am trying to paint a house currently (finished outside, now working on the inside)
new .zip update ready…see how that works
The new bld 44 zip is properly doing the meteotemplate API upload at the 5 second rate. :smiley:
Gus
thats good
what happened was when I added more real time data for when doing faster updates I had used a wrong variable which was not formated correctly and that was throwing out the api call
#-o :oops:
picture atttached of me painting clothes
:smiley:
