I know you put in code to stop logging: if you look back in this thread I tested it for you in March before you incorporated it into build S45. I tested it the simplest way: by pulling out the USB plug. What I have been trying to tell you since then (also in this thread) is that it doesn’t seem to work in real life. . .
before certain ducks needed to be lined up (which I had made tighter because the original change I made to please you I suddenly got emails from people who were getting problems with their wmr200 when they were not before)
I have redone it
there is info under view debug info, about what WD is up to
WD will exit then restart the separate wmr100/200 data reader
if still no data after a couple of minutes then WD will stop logging (and this is noted under view, debug info)
Wow! Where to start? I will try the test update, thank you. But I may not report for some time: I will wait for the next flat-line rather than initiating one.
Quote: “but Devil does not have a WMR200 so no comparison”. There is one common denominator for all reports of flat-lining - we are all running WD. As Devil says: “I thought to myself that if it can happen with one type, what is there to stop it happening with any other?”
Quote: “and it could have simply been that he had windows set to power down the USB”. Why are you so convinced that flat-lining is a USB problem? The fact that your S45 mod for WMR200 works when the USB plug is pulled but appears not to work when WD actually flat-lines suggests otherwise.
Quote: “. . . I suddenly got emails from people who were getting problems with their wmr200 when they were not before”. It’s a shame these people couldn’t go public on the forum so we could all benefit from the discussion.
don’t try to make things out of nothing
there is huge differences between weather station types
and those people who emailed me did not have problems like you were getting
I can’t understand why you are not now running this version (which I have tested with my WMR200 by disconnecting it etc) and I went to the trouble of working on for you etc
My weather station went flat line again. It has been doing this a few times a day now. I don’t know what has changed as it has been working fine for a while now. When it flat lines it has resumed normal operation on its own. One of the times I shut down Weather Display and restarted it and it started to work normal.
For some reason the USB sleep was NOT disabled. I did disable it before but for some reason it came ENABLED again. I disabled it again and I will see what happens!
the latest zip update of WD will try and restart the separate WMR200 program if no data is coming in from the USB
but that is not likely to fix it if windows has powered down the USB port
I just returned home from three days away and saw that it went flat line today. I have attached two screen shots. One of the Weather Display window and one of the windows settings showing the USB and hard drive settings.
Shall I try the latest Weather Display update? I haven’t done that since I found selective USB shut down enabled the other day.
Had to shut down and restart WD (build 58) manually this morning for a Windows 10 update/restart. On startup all appeared to go well: the history data was read and decoded and the DQ light showed green, and DR stayed red as it always does for a couple of minutes. Then DQ went red again and the data gatherer decided to shut down and restart - successfully, I might add. See debug info.
But as far as I know there was no need for it to shut down on this occasion. Is it going to happen every time I start up?
I am having issues again with my Weather Display 10.37s66 going flat line. It locks up. I can’t even shut it down with windows Task Manager or Process Explorer. I have to hold the PC power button in until the computer shuts down. It is totally random. It might go a week until the next lock up or it might go a day. Any ideas on what I can do to stop this? I did change weather stations but don’t think that is the issue as it worked for a while.
I have a Davis Vantage Vue station. Windows 10 home, 64 bit with 12 GB Ram. The weather station is on WU as KOHPATAS3. My current version of Weather Display is 10.37S66
Rick
