This weatherstation is compatible with normal WeatherDisplay. But it is not mentioned in the “config.txt” in the “consolewdfiles”-map.
What now ?
its possible I could look into adding support for this station
which pi version?
Don’t bother. I thought ConsoleWD could handle the same weatherstations as the GUI-version.
Peet Bros is not so common. I will use another solution (Meteobridge).
Thanks for clarification.
Mark
I should be able to get this working, as I have a Peet Bros console here now to test with
