My WD has stopped tweeting. Anyone else having this issue?
try deleting the twitter.ini file
and then also revoking access to the WD twitter program when you log into twitter
but also the problem might be that the tweet is too long
I’ve done all that. Now it will tweet, but only if I do it manually. I’ve tried resetting everything several times to no avail.
is there a wdtwitternew.exe program?
maybe your antivirus program deleted it
if so, re download from
http://www.weather-display.com/downloadfiles/wdtwitternew.zip
Well, I did that and it still doesn’t work. Wish we could figure out what has happened. This is weird.
what shows in
sentwtitter.txt
after running the
wdtwitternew.exe ?
This is what’s in the file after I manually triggered it.
8:22:16 PM 2/26/2017
there should be a second line, showing the actual data sent?
That’s all there is.
It will tweet just fine if I do it manually. For some reason, my twitter upload time have quit triggering it automatically.
The test send is done by WD itself
If you could send me your settings files I Will test
here
Which version/ build of WD?
I’m using 10.37S Build 42 . What exactly do you need for the settings file? I don’t see anything in my folder that says settings. Maybe that’s the problem?
there is a FAQ in the FAQ section of the forum for how to send me your settings files
