I am in the process of importing years 2013-2016 from Weather Underground. How do I get that newly imported data from Weather Display to show in the Saratoga Templates on my website?
Do the log files automatically convert to data files. After download I have a log file for the month and corresponding *.ini files in the datafiles folder. Do I still need to convert these files?
What NOAA reports do I need to create and do I just upload those to my website after they are created? There are four choices on the Average/Extremes/Reports tab in WD!!
Also, when I set up WD and the Saratoga Templates I set the start date for 2017, which template files do I need to change back to 2013?
I have a response from over at the WXforum, that I need to create NOAA reports, but not which ones.
This is what is required for the script. It is working fine for the current year, but not previous years that I imported to WD
Detail/Summary/Season Scripts Readme -
These detail/summary/season scripts are designed as add-on pages for the PHP templates available from Saratoga Weather. These pages use the dailynoaareport*.htm and climatedataout*.html files created by Weather Display to display the output.
Requirements:
You need to be uploading the dailynoaareport*.htm and climatedataout*.html files to your website.
Need to know where the dailynoaareport*.htm and climatedataout*.html files are located (default normally would be in the web root)
PHP5 on your website.
I will see what other info I can find out. You can look at my website scannorthcounty.net under the history tabs.
you can recreate past years climate data reports
when you view a past year/month climate report under view, av/ext, climate, that file should get updated (at least the climatedataout.html will be, and you can rename that. eg add on the month and year)
for the noaa report, when you view a past year/month report under view, av/ext, noaa reports, you can click to create the dailynoaa report there…and then rename that (it might already create a date stamped one)
then upload those created files to your web site
there is also the recreate tab…which will recreate alot of those files from a log file, that you could try/use
(slower as that uses the logfile instead of the data file)
