I have installed WD on a second computer set up in Client mode, using the clientraw.txt file system. Tabular data is showing up on the Client machine but graph data is not. Any thoughts on how I get the graphs to function?
do you mean you wanted the client version to use the server versions data files (for the graph)?
Got it sorted Brian, thanks. Was following instructions on one of your Help pages which suggested using the clientraw.txt but forget to mention that, of course, this would only provide tabular not graph data.
you just need to set the data files and logfiles location as the server logfiles and data files locations and then tick there to read only mode
(setup, advanced/misc setup)
