Hello, there is a possibility this webcam to bind in wd?
Because all my attempts failed.
Thank You
Thank You
Says it’s an IP cam…you should be able to point WD to the IP address. Check your documentation with the cam and see if they tell you how to grab images or video into your browser. Usually you need to pass a command and login details to access the camera.
